What I need to know is, where can I find Nissan part #s for bolts I need, with part numbers I can start sourcing out parts.
I have seen on GTRCanada I think some dude was selling hardware from his build years ago.
Need following: part #s
Water pump bolts/washers
Oil pump bolts/washers
OIl pan bolts washers (doing RB25 pan on 26)
T-stat housing bolts/washers
Engine mount bracket to block bolts L+R should be same (is RB26 aluminum and Rb25 steel bracket bolts same?)
Oil pick up tube bolts and oil splash/scrapper shield bolts
Complete hardware for intake side, ITBs, spacer, IM - need bolts/nuts and washers that go there.
Valve cover/rocker bolts with insulators
Bolts/nuts washers for timing components (idler pulley)
Upper timing gear cover bolts front cover and back cover
And center piece bolts for IG coil cover.
Thanks in advance, if someone can help me out or direct me in the right path, I would appreciate it on my slow build path of this RB26.
Thanks
Matt.
