Not sure what rolling fenders or stretching tires means.johnparkyourcar wrote:If you want aggressive, you can get lower offsets. Fronts high teens and rears mid to low 20 offsets. But then you'd have to roll fenders and/or stretch tires.
That's what I'm runningJeromeS13 wrote:245/35/19275/35/19
It's the most common size and has great variety/availability.
-Jerome
Why in the hell is that guy sporting a Nissan emblem???johnparkyourcar wrote:fender rolling is the process where you roll the inner lip of the fender up allowing you to run a more aggressive wheel setup or wider tires with out rubbing. Also to avoid rubbing you'd have to get a smaller size tire and stretch it on and add camber (top part of the wheel is tilted in compared to the bottom of the wheel).
But thats if you want a REALLY aggressive look.
not my car but example of rolled fenders/stretched tires/camber
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
