I've been searching, but forgot what the hell we were talking about.It's in this thread:
zerothread?id=246458
and direct links to instructions:
http://www.4x4parts.com/ubbthr...10524h ... e/727953/6
It's pretty easy. . basically, you take out the relay for the fog lights, open it up, solder a small piece of wire from one point to the next, then break off the tab on the bottom of the relay that's for switch power.
This works by itself, but you run the risk of leaving them on all the time. So what I did was then take out the relay for the AC, opened both up and drilled holes in the cases. . I ran wire through these, then soldered the switch powers together. The fogs only work when the vehicle is on.
You can also use a Radioshack relay, but mine crapped out so I started using the OEM ones.
The instructions make much more sense than my ramblings.
