PalmerWMD wrote: ↑Wed Jul 08, 2020 3:18 pm
Sounds like a good plan.
If the ATF that comes out when you do the drain as extra dirty, consider doing another drain/refill sooner rather than later.
Also these trucks are recommended premium fuel and do run quite strong on premium (once its "used to it", the ECU will set the timing more aggressive)
Chances are previous owner only used regular.
I used mid range on mine most of the time.. when I was in the mountains I used regular as altitude reduces the need for Octane.
When driving hard in summertime and/or near sealevel you may notice it pulls a bit harder with premium.
PS: At the age of the vehicle one might consider a new radiator at some point anyway.....it
is a decade and a half old vehicle.. when new these were generously sized but age reduces the ability to move away heat..
When the rad temp is elevated the ECU may pull some power.. and you may never know.. as with most modern vehicles the coolant temp gauge is dampened and only moves on larger temp differences.
In the meantime a "trick" is to take out some coolant, maybe 1.5 quarts.... replace it with 1 bottle of redline wetter water (reduces cavitation at the water pump and may increase heat transfer at the internal "fins") and top off with distilled water to thin the mix out just a tad for summer.. this will increase heat capacity of the system.
Be careful to properly "burp" the system.
Yes, I'm glad this is working out for him so far. This truck looks fairly easy to work on (I have quite a bit of experience with my 01 QX4 and see the similarities). Forgot to mention that I'm out in Denver. Because of the high altitude, I have put 85 gas in my truck the entire 6 years I have owned it and have not had any issues. I'm not sure if the R51 is as forgiving.
There are a couple items I want to look at on his truck that I'm hoping aren't serious:
1) his 4WD light stays on - transmission seems fine as well as 4 wheel drive during test drive.
2) high oil pressure gauge is showing high - possible sensor? oil level was fine
Putting together a checklist of things to get done for him:
-transmission drain and refill (a second drain/refill will be done if it looks necessary).
-new radiator (coolant drain and refill will be done) - Going to go with Denso and OEM radiator cap
-new air filter - aftermarket is fine
-new spark plugs - NGK
After this, new tires and alignment.
To be honest, I might start window shopping the R51's in my area, but I will keep my 01 QX4 because it's been good to me.
