Looking for 'History of VG/VE/VQ engine' PDF
Discuss topics related to the VG and VE series engines.
slipnfall
Car: '06 D40
Hi folks: just a quick 'one.... there used to be a PDF hosted here that outlined all the above engines and their technologies. Can anyone dig it up? I can't seem to find it.
Thanks!'slip
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Is this the one?
slipnfall
Car: '06 D40
Bingo, thanks!
PS - a bit off topic (hey, I can do that!), but meeting you guys at NOPI - AZ is what turned my eye to the max/i30. I'm thinking about picking up a 3rd gen SE in sad shape to get started. I just wanted a quick primer on the engine: I thought the above was a little more detailed, but there's plenty of info here I can absorb.
This is the *second* used 3rd gen I've looked into "locally" that suddenly won't keep the fuel pump fuse... of course they're 150mi away, so it's a bit hard to consider trailering it home. Does the ECM share the same fuse?
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Sorry for the delay. The only thing I can think of that would cause that would be the fuel pump relay. I don't believe the fuel pump and ecu would share the same fuse but I've found a good diagram yet so I'm going to have to go check out my car.
slipnfall
Car: '06 D40
Not a problem: I bought the car, but it doesn't seem to be doing it.
Regards,Jamie
Return to “VG30 / VE30 Forum”
