Does someone here has a compresion ratio of 9.5.1 pistons forged with forged rods in their sr20det redtop??? The reason I ask is because I am planing to rebuild mine with forged internals and I was planing to use 88mm pistons on 9.5.1 with forge rods and acl race bearing and use Cosworth Stopper head gasket. Anyone have inputs???
That is way I made the thread because I was looking for info. and could no find anyone that got that compression on a sr20det redtop and want more info.
Postby
Justin35ll »
https://forums.nicoclub.com/justin35ll-u118020.htmlSun Apr 04, 2010 4:41 am
You could do it, but most people find it easier, and more reliable to just run higher boost.It's basically doing the same thing by making more cylinder compression.
But if you're set on doing it I would get the block resleeved if you're going with 88mm pistons
