strikingimage240 wrote:Alan from project240 has a full ss clutch line from the slave all the way to the clutch master cylinder. Where can i get this from? It is supposed to stiffen up the clutch pedal alot
But the only part that flexes is the short rubber piece. Ideally, you would want the whole line to be hard line, but since engines move around on motor mounts that isn't possible. There is no advantage (that I can see. Even the SS line will flex more then steel hard lines) to having the whole line from clutch master to clutch slave cylinder being the braided ss clutch line.
