If you buy a 1995-1996 they won't.dhellmer wrote:thanks for the advice,, do the j30 and other options require aditional upgrades as well like the z32?
Just need an abs driveshaftdhellmer wrote:thanks for the advice,, do the j30 and other options require aditional upgrades as well like the z32?
let me rephrase it. Will need a abs driveshaft when running a solid one piece driveshaft. However stock drive will workTulsa_S-13 wrote:Not necessarily true. Although the J30 differential is slightly longer, I do know of people that have used them in conjunction with their stock driveshaft. There apparently is enough play to get it all to fit, although this might cause extra wear on the rear transmission seal. Luckily, it's easy to replace.
weld the diff... it cant be any cheaper than that lol less than 5 bucks loldhellmer wrote:I have a 1991 hatchback 240sx with an sr20det swap, needing a better rearend. Looking into LSD's cheapest i have seen was 600 and thats out of my price range, however i want one for summer time. Any suggestions? Other then welding the spider gears together lol
Thanks
