looking for cams and cam gears
Discuss topics related to the VQ series engine.
stillena33driver
Car: 2003 Nissan Maxima
does anyone kno where i can find a sweet *** deal on some cams and cam gears for my 03 nissan maxima thanks guys
Loki2daMax
Car: 2001 Nissan MAxima SE Special Edition
i wouls like to know also
C-Kwik
It's doubtful they exist. The later VQ's use variable cam timing. I've never heard of any for the VQ, but at best, I'd think it would only exist for the exhaust cams, but I'd be inclined to say they do not exist for the VQ.
C-Kwik
I should be clarify that I was referring to the cam gears only.
nismo1219
Car: '12 Nissan Altima 3.5SR
'99 Nissan Maxima GLE
i dont know of any "sweet *** deals" but i know you can find a set of camshafts on sportcompactonly (which is a nico supporter) for about $1,000. i think stillen may also sell a set, but i dont really remember off hand.
maxhopper
Car: 02 Maxima SE 6spd
Stillen sells cams for the VQ35. http://www.stillen.com/product...00035
DamSedan
Car: None at the moment RIP Subaru's
What are you planning to run for your engine management once you get a set of cams? I had some Jim Wolf cams in my old Sentra (S2's I think) and the idle was lumpy. Basically with an ecu retune it would have smoothed things out a little as well as gotten the most HP out of them. I mean, sure you are gaining a little but you are leaving just as much hp on the table at the same time. I can not say enough for engine managment tuning!
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
here's JWT
PART NUMBER: A3503-N00C2
THE JWT C2 PROFILE IS CONSIDERED A RACE GRIND AS ARE ALL OF OUR "C" SERIES CAMS AND IS DESIGNED TO OPERATE WITH JWT SPRINGS. THIS IS A DESIGN WE ARE EXTREMELY PROUD OF, AS IT IS A VERY TIGHT DURATION FOR THE LIFT AND REQUIRED AN EXTREMELY PRECISE PROFILE TO SAFELY MAKE THIS LIFT AND STILL STAY ON THE STOCK FOLLOWER DIAMETER. THE TIGHT DURATION AND HIGH LIFT ALLOW THE C2 TO PERFORM WELL AT MID TO HIGH RPM IN NATURALLY ASPERATED ENGINES AND YET THE C2 HAS SEEN OVER 800HP IN BOOSTED FORM!
PART DESCRIPTION: C-2 JWT CAMSHAFT SET VQ35DE 261 DEG. / .456" (11.58MM) LIFT RACE CAM SET FOR NA AND BOOSTED ENGINES
FITS:350Z, MAXIMA, PATHFINDER, G35, ALTIMA 2002+, MAXIMA 2002+, MURANO, FX35,
ENGINES:VQ35DE
PRICE: $1,198.00
PART NUMBER: A3503-N00S1
260 DEG DUR. / .428"(10.9MM) LIFT, INT. ADVANCED 2 DEGREES. ** NOTE: THIS CAM UPGRADE MAY REQUIRE THE IDLE RPM BE SET TO 850 RPM TO PREVENT POSSIBLE STALLING AT IDLE. 2004+ LEV II VEHICLES DO NOT ALLOW FOR IDLE ADJUSTMENT AND SHOULD NOT USE THESE CAMS WITHOUT SEEING OUR TECH SECTION ON IDLE STABILITY MODS. WILL NOT WORK ON 2005+ REV-UP ENGINE WITH EXH. CAM CONTROL.
PART DESCRIPTION: S1 CAM SET FOR VQ35DE**. JWT S1 BILLET CAMS ADD 15+HP WHILE MAINTAINING EXCELLENT DRIVABILITY AND GOOD IDLE QUALITY. EVEN MORE AWESOME WHEN COMBINED WITH A TUNED EXHAUST AND OUR POP-CHARGER INTAKE SYSTEM.
FITS:350Z, ALTIMA, MAXIMA, XTERRA, G35, ALTIMA 2002+, MAXIMA 2002+, MURANO, FX35
ENGINES:VQ35DE
PRICE: $1,198.00
Loki2daMax
do you know if the reprogrammed ECU from technosquare be able to work with the JWT cams or would I still require the ECU from JWT?
nismo1219
hey bro - check out all the goodies that come with a greddy emanage ultimate! for engine management, thats the way ill go when i get the cash, plus i have heard alot of good about it as well!!
Q45tech
How will you pass emissions with cams and ecu change?
nismo1219
why wouldnt it pass as long as the CEL wasnt on??
brianw
Car: 4-doors, 5-speeds...
Technosquare should be able to handle the ECU reprogramming if you don't want to go to JWT (or if you already have a TS ECU), especially if you're willing to fork out the cash for a custom tune.
350Z cams will fit, so you have tons of choices-- I'm really only familiar with the JWT 350Z S1 and S2's, though. I don't think C2's are practical on a street car without extensive ECU tuning, plus the lope at idle will make passing emissions a dicey proposition at best.
95prmax
Car: 1999 Nissan Maxima SE-L
question do you have the 3.5 or the 2.5 if you have the 3.5 you can use the r-tune cams or are they called z-tune cams for the 350z they bolt right in with no problem
blondstrat57
Car: 93 240sx Vert, 94 Z32 Vert
Normally I wouldn't post FS's here, but since you asked: I just picked up a set of very very low miles (like less than 1k) 2002 Maxima VQ cams. They were from a new engine torn down as a racing parts donor that weren't used. They are stock now but as someone here mentioned there should be several grind choices available for 350 etc. (a race grind would be a very bad idea for the street I think) A new core set is 640 from Nissan, but I'll take a reasonable offer. I'll also post some other FS's later of a few more very select VQ engine parts. Please email [email protected] if you would like them-they are sweet..peace. Jim
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
