looking for an LSD
fullmetal
Car: 240sx, up for sale!!
I am trying to find a LSD for my 91 240 sx it came with an open diff and I really want to upgrade cause I just cant grip or drift or anything with it the way it is does any one know of a good LSD to swap in? I was looking into the cusco but it looks like it only goes with the sr20det and not the KA24DE is this true? thanks for the help
DRFT(kinda)
Car: 2005 Nissan Titan.
*sigh* First off; periods (.) are not only cool and fun to use, but it helps everyone read your post. Second; to answer one of your questions, a LSD will work with any motor you put into your 240, its the same rear-end no matter what motor. And to futher help everyone with you question, what type of driving to you plan on doing with the LSD, i.e. drifting, autox, drag? That is the biggest factor in picking out a LSD.
fullmetal
Sorry about the slopyness of the first post, I had to do it between classes. I plan on doing mainly auto-x and hill climb with the car, as well as some daily driving. As far as the fact that any 240 rear end can be used with any motor I did not know that they all had the same drive shaft fittings so I appologize. The main question that I have is as to what brand/ type I should look in to. I know good things are said about the Quaife LSD and the Cusco. However I do not belive that Quaife makes a LSD for the 240sx. I like that the Cusco can be changed from 1.5 to 2 way and that the RS is still viable for daily driving. Does any one know of any other companies that I should be looking at, or if I am wrong about Quaife?
DRFT(kinda)
Go herehttp://forums.nicoclub.com/zerothread?id=197177
Just had a big disuccsion on different types of LSDs and what they are all good for.
