Looking for an Air Regulator
mikehutch711
I had been having alot of trouble with idle, and i narrowed the problem down to the air regulator. I removed it, connected both hoses with a piece of pipe, then drilled a hole in the pipe to atmosphere and the car idles perfect now. (took alot of time, and was a fluke figuring out this solution)it works fine, but noone likes a vaccume leak, so im looking for a working air regulator.Anyone have one?
Modified by mikehutch711 at 1:55 PM 2/13/2006
float_6969
I think you can do some slight wiring modifications and make one from an SR20 Sentra work. I've got one sitting in my garage that I'm going to make work, but I haven't actually done it yet and since I picked it up from my girlfriends dad's shop, I don't know for sure what car it came off of.
mikehutch711
i checked most other nissan air regulators and they all wont fit. ka24de, other ca's.The ca18det has 2 pipe connector pieces, all others have 1 pipe piece, and 1 block connector piece.Ill try dig up images that will show what im talking about
mikehutch711
here is the ca18det one, and the one i found on other nissan cars.Rafic tried to make me an adapter for the other one, but it wouldnt fit (pretty tight area in there)Need ca18det regulator.
T88lexus
I have KA one that I made it to work.. it was not hard at all.. just weld the pipe to make it like ca one.... working fine on mine
pulsar gtr
Car: NISSAN VEHICLES
HI Mikey,
I haven't forgotten about the air regulator but I haven't ran accross one from a ca18det yet, I got few ca16de ones and the one I made for you, I also made few for other members and they worked fine, but I believe you were saying something regarding some pipe is close to it(cold pipe).
I will continue to look for one and Hopefully I will luck out with one.
RafiPULSAR GTR
mikehutch711
Rafi,With the combonation of the cold pipe and radiator hose, its very hard to make it fit properly.
thanks rafi
float_6969
I'm tellin ya, I've got one in my garage that is a straight through, just like the CA. The plug is different and you'll have to cut the plug off of the SR20 Sentra that you took it from, but otherwise it should work. I'll write more up about it later when I install the motor.
float_6969
Here is a pic of what I'm talking about. I don't know what car it came off of but you can ask biosehnsucht, as these are pics of his motor.
float_6969
and #2
biosehnsucht
HAH! Those are original CA peices! :P
mikehutch711
hmm thats exactly what i need.what yr car does it come off?sentra right?If i cant find @ junkyard i might have to get new from nissan :S, but then i still need plug
float_6969
dude, the one on my car doesn't look like that at all. Maybe Nissan changed it at some point? I know that the one that you have on your car is just like one that I got from a Sentra, and it doesn't look like the one that was on my car originally.
float_6969
I got mine off of a '92 Sentra SE-R...
biosehnsucht
22660-93L00 is the air regulator used on automatic CA18DET S13's from 91 onwards (in europe) and on automatic SR sentras from 91 onwards as well.
there's some other #'s for manuals and earlier automatics, but not locally available. actually the early automatics are same as manual, so likely they just 'upgraded' to a higher idling valve.
that SR part should be fine regardless, might also look at 22660-53J00 which is the SR sentras's manual part#, not the same as CA but should physically fit and likely idle lower since its MT also.
float_6969
The only problem I have with mine is that it won't plug in. I'm going to have to screw with it to make it work. The plug is close, but not quite the same.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
ive just taken it out and put a length of hose in place of it, both cars ive done like this seemed to run fine
cant really remember since mines been down for a year.
float_6969
The problem with doing that is that your idle should be real high.
Not_a_sr
roughly around 800rpm -900rpm
float_6969
Thats kinda high, but not too high. Mine idles from 750-800
boost_boy
If you really need one of these things, let me know because Ihave about 2 or 3 good ones somewhere in my closet.
Dee
