i know exactly what you're going through. ive been researching my stanza for 4 years with sparse luck. but i have a good bit of info for you. i hope that anything you find on your own you might relay back to me.suspension-
http://www.airbagit-store.com/application_list.asp search your car and there should be some coilovers for the stanza, but i don't know that i trust them, no brand name or any information at all. http://www.ground-control-stor...CA=93 coilover conversion set that looks pretty good, prolly what i will do soon. replace the original struts with KYB Blue series and add this, and it should work well, i think. if thats not for you then just replace the struts(im sure theyre worn out as hell) and some eibach springs from stillen will work well, also.engine-
http://www.jimwolftechnology.com/index.asp http://www.stillen.com/ search stanza and altima on both of these and you should get plenty of results. the altima headers might work, but im not positive.lower end- cams-
http://www.pdm-racing.com/products/cam_corner.html these guys look like they do very good work pistons,rods-
http://www.briancrower.com/mak...shtml the SOHC(stanza) and DOHC(altima, 240sx) fit the same pistons and all that, so theyre easily interchangeable. clutch/transmission- centerforce and ACT both make clutch kits for the stanza.theyres a good bit out there, it just takes time to look.good luck, hope to see your blown stanza on the site one day.
