Looking for advice on how to replace idler pulley in 2013 Rogue
osmonxp
Car: 2013 Nissan Rogue
I need to replace the idler pulley in my 2013 Nissan Rogue but the pulley is behind the frame, I can't fit any tools in there. Any advice on how to get this done?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The Idler is only one bolt, but it's pretty much impossible to access from the bottom. The simplest way is to remove the passenger side engine mount and jack up the nose of the engine. There's no easy out, Motor quotes 1.3 hours even for a pro with power tools and a lift.
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
VStar650CL wrote:
Thu Jul 07, 2022 6:55 pm
Vstar - can't you get at it by pulling the passenger side wheel and the inner fender?
VStar650CL
Technical Expert
The tensioner yes, but I never had any luck getting at the idler that way. Fortunately they don't crap out very often, but working from the bottom, the tensioner is in the way and you're working almost blind. The nose mount and wishbone are only about a dozen fasteners, then you have a good look and a much better working position. If you have a leaky rocker cover then count it as a bonus, you can change it while the mount is off. ;)
Return to “Rogue Forum”
