limecorrado wrote:Does anyone have part of the harness which connects to the dropping resistor, or know what other car might have the connector.
I think I got the connector from the window wiper motor on a Maxima or something at the junkyard.. just take the dropping resistor with you and try to find something that fits, I had to repin the connector but it'll work fine..
Quote »Also can someone discribe the vacuum hoses go,
What i see1 above the turbo,1 on the wastegate,4 under the intake manifold (Grouped together),1 small one at the back of the intake,1 large one at the rear of the intake(Brake Booster),1 under the throttlebody, and then 2 one the metal plate with the ignigtor.
I would like to use one vaccum hose for my boost gauge and another for my HKS ssqv bov.[/quote]the 4 on the manifold from top to bottom:- boost/vacuum source (FPR T's into it on the back side on MT only, you can get signal for boost gauge from this too, it also goes to the vacuum chamber for the secondary butterfly control if you hook it up correctly)- FPR (on AT only, it's hooked in through a solenoid to boost pressure for hot starts which then is hooked to the top one)- secondary butterfly actuator- filtered unboosted air (goes around the back of the engine on the same bracket the water return is from the turbo, then plumbs into the turbo inlet pipe next to where the crankcase ventilation - within this there is a T to a solenoid the JDM ECU uses to control boost)
the easy way to make things 'work':leave the stock T between FPR and back of plenum and top of the four pipes, loop the top and 2nd from bottom pipes at the other end (which connectsthe actuator to boost/vacuum) OR just T the FPR, actuator, and plenum together.
on the turbo, run a vacuum line from compressor outlet (there's a vacuum nipple there) to the wastegate
the 'correct way':you'll need a vacuum chamber/tank and a checkvalve (or a tank w/ one built in, I'm using one from a 1st gen (I think?) protege that has it built in)
at the back end of the pipes:- the FPR is T'd into the plenum and to the top of the four pipes- nothing on the 2nd pipe from the top (would be FPR & it's control solenoid on AT)- the butterfly actuator connects to the 3rd pipe from the top- the unboosted air line (see above) is connected to the 4th pipe
at the front end of the pipes:- top pipe goes to check valve (allowing airflow TOWARDS manifold, AWAY from vacuum tank) then to vacuum tank- nothing again on 2nd- 3rd pipe goes to actuator control solenoid- 4th pipe goes to actuator control solenoid
the vacuum tank & actuator control solenoid:the vacuum tank on one side goes to the pipes (see above), the other to the solenoid, and the solenoid connects also to the filtered atmos (the bottom pipe) and the actuator (3rd pipe).
If you look at the solenoid (pretty much any KA 3 way solenoid at least) you'll notice it has two pipes at one end (one of which is straight along the axis, the other sticking out at 90 deg angle) and one at the other (on axis)..
IIRC the one by itself should go to atmos line, the other one opposite should be the tank, and the one at 90 deg should go to the actuator. I can check once I get home.
Finally, the ECU boost control if you want it, invloves another solenoid on the left side of the engine bay by the turbo. Instead of connecting the wategate directly to the compressor outlet, T those together and the other part of the T goes to the solenoid (normally closed, not sure which end off hand) and then the common part of the solenoid goes to the fresh air line going around the back of the engine from the turbo inlet (T'd in) and the 3rd part of the solenoid is just cap'd off.
The way it seems to work is when the ECU is < X boost is just leaves it open so that the wastegate doesn't get as much boost from the compressor (since it's recirculating the bit that would make it start to close) and then when it hits X it closes it SNAP instant opening and boost control.. that's my theory anyways.
I'm not hooking that up, just going to get a real controller eventually. It's just a little too crazy for me, altho if I get bored I might try to verify how it works and see if it really is tunable, cause i would be nifty if I could romtune it.
When I get home later I'll try and make a more coherent post, that and make sure I didn't screw any of that up. We just mad haxed the FSM and FAST systems the other night to figure out where all this **** should go... but I'm tired and brain is not operating 100%.
