Neil »
https://forums.nicoclub.com/neil-u15642.html
Sun Aug 28, 2005 5:14 pm
you mean convince?
redtops are starting to show their age... ive heard horror stories of the older SR's (redtops) weird rocker fork thing assemblies failing and leading to munched valves, cuz SR's are interference engines. Honstly noone wants to let you know what kind of conditions it was stored in and for exactly how long before they powerwash/degrease it, tie it to a pallet and send it to you. The only way someone can get compression on a motorset is cold. Otherwise theyd have to mount it to something and hook up a cooling system and some sort of fuel delivery, plus the ecu which takes time for them and is annoying so they may not have even done it if they say they did... plus cold comp checks are inaccurate, and dont even tell you if its got good oil rings or good oil pump if they even did go thru the effort of cranking it over cold. And then theres no telling the condition of the turbo or getting it replaced buy the seller if its bad cuz its considered a 'wear item' like the water pump.
if you spend the $$ on a front clip, a place like Jarco will send you a video of it running and they do compression checks while its Hot. Plus clips come with everything you could possibly need for a stock sr setup, and you can steal the front brakes & it might come with a better coldpipe or some other goodies and all sorts of hardware and hoses and crap youd never expect to need. you just gotta remove 2 engines, and cut up and haul away the half cut when youre done.
You can easily get 230whp SAFELY out of a KADE for around $3k including new Gt28R turbo. cheaper if you cut corners like using sr smic, stock pistons, used t25, etc. With a good tune, as long as the motor was/will be well maintained, a stock KADE should last well over a year of daily driving if you turbo it at 100k+ miles. Might need rod bearings prematurely.. but arguing that, new rod bearings + piston rings + cometic head gasket +felpro upper gasket set + ARP head/main studs will be around $650. then yr talkin really good longevity and reliability, as long as you dont turn up the boost a lot.
either way it costs $. but the only reason id get an SR is because it looks trick in the engine bay.
