jdkno wrote:Didn't want to start a new thread for this, sorry for bringing back an old post.
headhunt3r - I am looking at thoes same wheels for my 08 Precision Gray sedan. From what I am finding they are 18x8 w/ a 30mm offset. Do you have any probelms rubbing? My suspension is stock and I plan to keep it that way. What tire size are/were you running on them? Did you need anything special like spacers or anything? Looking at the specs it seems as though these wheels with the 30mm offset will push the wheels out almost 1" vs. the stock 18x7.5's with their 45mm offset.
I am either going with the G35 wheels or the SE14 G37 look a likes in 18x8.
However I am considering getting them powdercoated to match the GT-R wheels prior to putting them on the car.
I have them with Eibach springs and I have zero rubbing issues with them. They are wrapped with 225/45/18 rubber all around. The wheels are labeled front / rear behind a spoke but spec wise they're identical so having the same rubber allows me to rotate them without too much trouble.
I did not use any spacers. The fact that they put out an inch is IMO a good thing. It gives the car a much better look, and closer to the "flush look" a lot of people shoot for.
I would, however, recommend that you change your plans of keeping the stock ride height. You'll see what I mean if you install the wheels. :p
