Actually the reason alot of ppl are having problems with the Cometic MHG is they are failing to get there BLOCK and HEAD decked and resurfaced. The only reason you can get away with not doing that with the OEM HG, is because cork (or whatever the material is) conforms to defects....MHG's don't form to defects. The 88.5mm bore Cometic MHG will work on the stock block (86mm). Just make sure to get your head and block decked!!otterman wrote:I heard that the reason a lot of people have problems with Cometic HG is because when you order it from Enjuku, 240sxMotoring, etc. the bore on the headgasket is larger then the bore on the SR. I don't know if that's true and causes prolems or not. Cometic is 88.5mm from those stores but the block is 86mm.
If you call Cometic and order from them they can make you a 86.5mm and its actually cheaper cause you don't pay the store mark up price.
Yeah it sucks when that happens. Any chance you have called cometic directly and spoke with a rep? Jeff at heavy trhottle said that the PE HG's are a little better quality so maybe that will encourage you to use it. Is it still new?driftin_sr20det wrote:Your right alot of MHG failures are because of not getting the head and block decked. But, what about people like me who do and still have problems. I heard plenty of stories and still attempted to try their product and I get to join the group that has been burned. Oh well though, sh@# happens right. I took a chance and wasn't on the good side of the stick.. hehe
