Looking for a flexplate...
freespirit3368
Car: 1990 nissan 240sx, 2003 Audi TT, 2003 Chevy Avalanche
Hello,
I am looking for a flexplate for an AUTOMATIC CA18DET swap that's in a 1990 240sx. Does anybody have one? I can't find one anywhere and i need it like yesterday. Thanks
HighwayStar22
Car: 2002 RSX Type-S, 1991 240 Hatch
I'm 99% sure I still have one. I need to check the box of parts. I believe it was a half moon iirc?
freespirit3368
It looks just like a flywheel. A big wheel with teeth and an 8 hole bolt pattern in the middle. Not sure ow else to describe it. If you can send me a pic of what you have, I can tell you if that's what I'm looking for. Thanks
freespirit3368
Also, I know most of the parts on the CA18DET are interchangeable with the ones off a CA18DE from the 1988 Nissan Pulsar NX SE. Does anybody know if the flexplate from a Pulsar would work with my CA? Thanks
float_6969
I doubt they are interchangeable. They flywheel and clutch won't work, so I can't believe a flex plate would either.
See if you can get one for an S12 200sx w/a CA18ET. THAT flexplate should be the same. You also might try over on club-s12.org
