bruinbear714 »
https://forums.nicoclub.com/bruinbear714-u1106.html
Tue Oct 08, 2002 9:59 am
just pick the year that you like best... there are at least 5 different 240sx body styles you can choose from: hatch, 91/92 coupe, convertible, 95-96s, and 97/98 styles.
Mechanical wise, you should look for the timing chain rattle and the tapping noise from the valve train. 240sx are as notorious as supras and head gaskets when it comes to the timing chain rattle and valve train knocking.
Also look for the heat shield rattle when you're shifting gears at high rpms... although this is easy to fix compared to the timing/valve problem.
