Thought I would add 2008 expenses to this list to give a 2 year snapshot in one place . The Q performed extremely well this year, and again never broke down or failed to get me where I needed to go....got close with the MAF failure, but quick diagnosis and Joe overnighting the part prevented a breakdown.qship96 wrote:I was going thru my log and thought I would share the maintenance items done in 2007,maybe it will help a newbee someday see how the old Q`s require a steady cash infusion! Keep in mind,all the items were performed as preventative maintenance-the car never broke down or any component failed throughout 2007
4 Redline oil changes/60u00 filterstransmission fluid exchanged with 14 qt redline d4Rear diff 2qt redline gear oil replacedPower steering fluid exchanged 2Qt Redline d4Brake & traction fluid exchangedRadiator fluid exchanged=Prestone long lifeNew radiator and hosesNew a/c compressor and dryer {brand new from Joe}and vac/rechargereline front brakes/factory pads/turn rotors3 wheel balances/rotationsnew exhaust mountsnew upper linksnew remote key fobnew seat side trimnew center pillar covers for outside b pillarscomplete plenum job all hoses/knocks and harnessvalve cover reseal/plugsnew belts,pullies,waterpump,thermostatnew oxygen sensorsfuel/air/pcv filtersreplaced both fog lamp side trim pieces
I think that is it as far as I can see from receipts...total costs for above items in 2007 was $5720.....an expensive year at $476/month average.
Yeah, that retained 12% of old, worn out contaminated fluid, detritus and varnish really hops your transmission!qship96 wrote:transmission was drain/fill thru via drainplug multiple times to reach 88.00% new fluid. Not interested in BG machine flush, or other machine based fluid exchanges at all....even for free
I spent about $600 maintaining the 94Q this year. Brakes and fluid changes were all she needed. The first 2 1/2 years were brutal though ($8000+).Jesda wrote:Whats comforting though is that these parts are mostly wear and tear, not unexpected failures.
Agreed. Or Jerry Tucker in San Diego. It's sunny and warm there this time of year. With all the work you've done your Q should run like new.qship96 wrote:Alexander, considering all the $ you have invested in your Q, and having owned it since it was a baby....why not ship it to T3 in Atlanta to get fixed correctly then fly out for one awesome drive home? I am confident it is just a malfunctioning sensor or combination ofsensors causing your issues.
I agree with you 110%!! You should never let your fluid get so bad that its ever "varnished" or "contaminated". My guess is the redline that you took out of the trans probably was about 80-90% as good as it was right out of the bottle!!qship96 wrote:UGHHHHH Brian, that HUGE 12% leftover fluid wasnt old, dirty or varnished........it only had 25,000 miles on it from the prior flush......proof is in the pudding as my factory original transmission operates like new at 222,500 miles
You seem more fixated on the machine PROCESS than the END RESULT, which for me is a correctly operating transmission
Do you flush your gas tank before refilling also???? Just think of those few old gallons left in the tank CONTAMINATING your new fuel.....see how stupid youre being?
REREAD my comments, I said the car never had a breakdown....not that parts dont wear as they age AND ARE REPLACED BEFORE THEY FAIL....A/C compressor was still functioning at time of replacement, it was just not efficient at low RPMS{idle} worked fine at highway speed.....worn.Victor wrote:You just replaced your air conditioner compressor for the hell of it? Sounds like it was a repair to me, together with a lot of other stuff. If you knew in advance how much you were going to spend would you still have done it? Might have been better to put the money into a newer car that didn't need so much maintenance. How many miles did you put on the car in 2007?
Maybe, but not using the ATF he wanted to use.Paul Wall wrote:And for a bit more you could have taken it to the dealer or have a shop do it using the BG fluid.
Did you replace the "new center pillar covers for outside b pillars" because of discoloration?qship96 wrote:I was going thru my log and thought I would share the maintenance items done in 2007,maybe it will help a newbee someday see how the old Q`s require a steady cash infusion! Keep in mind,all the items were performed as preventative maintenance-the car never broke down or any component failed throughout 2007
new exhaust mounts
new upper links
new remote key fob
new seat side trim
new oxygen sensors
Did they turn grayish too? Mine are not dark black and I'm wondering if they ever were when they were new. What are the chances you took some pics of your old vs new?qship96 wrote:Yes, it almost looked like the clearcoat was failing on the pillar covers- made a huge difference!
