Looking at buying an 83 810. Any advice from the datsun gurus?
Here you'll find topics regarding the Datsun B210, 310, 610, 710, 810, 1200, and lots of other models - All are welcome!
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Here's my original thread in Maxima general post there or here, whichever:zerothread?id=131718
Any advice, suggestions, what to look for, etc?Any information about the engine (L24) you can provide would be GREATLY appreciated.
Thanks guys! I appreciate it!
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the L24 is the smallest domestic variant of the Datsun L6 engines, they tend to last about 300k and don't tend to leak oil untill they have been rebuild had the headgasket redone or some other major work, the will take all kinds of a beating, in carb'd form I ran my stock L24 to over 8k revs and never hurt it, the max/810 used a lower compression head and fuel injection other than that it's the same engine used in the 240Z, you can bolt a 2.8 in place or even add the 81-83 280ZX turbo motor with littel effort, if it's not ate up with rust buy it ! us datsun geeks love finds like this
Mig
Car: 1978 280Z, 1979 810 2dr, 1964 L320 Pickup, 2006 Chevrolet HHR 2LT
evildky wrote:the L24 is the smallest domestic variant of the Datsun L6 engines, they tend to last about 300k and don't tend to leak oil untill they have been rebuild had the headgasket redone or some other major work, the will take all kinds of a beating, in carb'd form I ran my stock L24 to over 8k revs and never hurt it, the max/810 used a lower compression head and fuel injection other than that it's the same engine used in the 240Z, you can bolt a 2.8 in place or even add the 81-83 280ZX turbo motor with littel effort, if it's not ate up with rust buy it ! us datsun geeks love finds like this
Actually, bolting up a L28E/ET in a 810 or 910 (RWD Maxima) is not that easy. The L24E used in these cars have the oil pan sump in a different location than the other engines due to the steering setup. I once thought about doing this with my 810 but it would involve some machine work on the bottom end of the L28E/ET to allow the pickup to work with the L24E oil pan.
evildky
06 Nissan 350Z GT
where si the sump on the L24E? most of the Z's had a mid sump but the 81-83 turbo used a rear sump, and they share a pickup
Mig
evildky wrote:where si the sump on the L24E? most of the Z's had a mid sump but the 81-83 turbo used a rear sump, and they share a pickup
At the front
evildky
06 Nissan 350Z GT
Mig wrote:
At the front
so you'de need to use the 810 pan and pickup? or is the block cast for a closer pickup?
Mig
evildky wrote:so you'de need to use the 810 pan and pickup? or is the block cast for a closer pickup?
Check out this thread. Post #12 by Zcarnut talks about the diferences and how to modify the block to use the 810/Maxima pan.
http://forums.hybridz.org/showthread.php?t=101289
Return to “Other Datsun Cars”
