BadQ45t »
https://forums.nicoclub.com/badq45t-u300.html
Sat Oct 08, 2011 10:09 am
I would also strongly suggest you find a local transmission shop to look carefully at the transmission, also see how many times your friend put in fresh fluid. If the transmission dumped 1k after you buy it you may as well have it towed directly to the charity organization.
I would say there is alot of other risk, but 3k isn't alot. However, if you have to dump 5k into it in the next year, the number climbs quickly. Give us some help with some full sets of records and tell us how often you see full fluid exchanges/flushes (and if possible what type synth or conventional), full tune-ups including spark plugs, and especially other things like Knock Sensors (they are shot if original), coil packs, alternator, starter, shocks/struts. Those are all at end of life at this mileage, so if he's not done them you will have to shortly.
If these are all taken care of, 3k is fair. If not then this is a ticking time bomb and I'd tell him to pawn it off on someone else or lower the price to 1k and just drive it until it explodes and you get a $500 charity deduction.
