it's sweet, except i was using the phone when i posted. on the twah-lay.AppleBonker wrote:How's typing on that PS3 controller doo-dad working out for you?
excellent info. grassy a**.A33 wrote:The biggest nightmare with maintenance from my experience is the sensors, mainly being the crank and knock sensors but it doesn't seem to be a common issue if the car isn't neglected. They're a little steep to replace, I think I looked into the knock sensor and it was $250-300 which turned out to be the issue because the new owner took the risk and it fixed the problem. I didn't know enough about the cars or how to test the sensors at the time to try to track down the problem, plus I didn't have the funds at the time to play test the sensor or pay someone to do it for me. I had this car 5 years ago though and as I mentioned earlier it had a long list of problems for a Z32.
If you stay on top of the basic maintenance of the car I think you'll be fine, the one I mentioned earlier was bought by her father brand new and as far as I know he still uses it as a daily driver to commute 60-70 miles round trip a day. He said he got in the low 20's as far as fuel mileage goes and I never recall it having to be in the shop for anything major other than just basic maintenance.
I'm not quite sure why people think they're such dogs as far as power, compared to the 2 91 Mustang GT's(I started out as a Mustang guy) i've had it felt like it had comparable if not better power but tons better handling. Now compared to my 88 RX7 Turbo II, no comparison in my opinion. I have quite a bit of love for all generations of the Z though but the Z32 is one of my favorites along with the 240-280Z. If it turns out to be a good buy, I think you'll be pleased with it.
need t-tops. it's definitely a 5-speed. i spent a goot 10 minutes just sitting and staring at the 240 last night. then i wailed on it a bit on the way to work this morning. it'll be hard to see it go if this z checks out. are 2 z's better than 1? idk yet, but i might be finding out.Bwana wrote:The z32 is an excellent car, though heavy and somewhat over-teched for it's time. Just don't ruin your experience by getting the worst trim available. I've driven a NA, T top, 2+2. They're dogs.
Get a 5speed, NA (if that's what you want), slicktop and enjoy!
newer= betternumbnuts240 wrote:update, it's a 92, not 91.
ok, that was kind of a weak update. sorry.
With one very significant exception: '96 is the worst Z32 of all. OBDII caused the loss of VVT. Not cool.sx moneypit wrote:newer= betternumbnuts240 wrote:update, it's a 92, not 91.
Trouble Spots
Clutch: On turbocharged models ,the clutch may slip because the clutch-pedal return spring is too weak. (1990-91)
Fuel pump: Adding fuel-injector cleaner to the gas tank can cause corrosion on the fuel injector coils, which will eventually damage them. (1990-94)
Poor drivability: A problem with the power transistor causes drivability and idle problems, and there was a voluntary recall to replace it. (1990-93)
Power seat: The original power-seat switch sticks out and is often kicked and broken, but there is a revised switch with a shorter lever and stronger housing available. (1990)
Water leak: Leaves and other debris can collect in the evaporator housing, clogging the drain and causing water to leak into the passenger footwell. A revised cowl screen is required. (1990)
Windows: The power windows may shudder during operation requiring revised window regulators (1990-91), or the windows may not operate due to dust building up in the main power window switch. (1990-92)
Consumer Guide® Estimated Repair Costs
This table lists costs of likely repairs for comparison with other vehicles. The dollar amount includes the cost of the part(s) and labor (based on $50 per hour) for the typical repair without extras or add-ons. Like the pricing information, replacement costs can vary widely depending on region. Expect charges at a new-car dealership to be slightly higher.
Item Name Repair Cost
A/C Compressor $730
Alternator $535
Automatic Transmission or Transaxle $1,620
Brakes $350
Clutch, Pressure Plate, Bearing $450
Constant Velocity Joints $1,400
Exhaust System $370
Radiator $400
Shocks and/or Struts $1,300
Timing Chain or Belt $340
Looks like there's hardly no difference between the 91 and 92numbnuts240 wrote:update, it's a 92, not 91.
I really need to quit reading about all this Z32 stuff, or i'm going to end up having to get another one myself.1991 Nissan 300ZX: A driver's airbag became optional this year, and a new base model joined the lineup. Additional standard equipment included heated mirrors, an illuminated entry system, a cargo cover, and automatic temperature control. All except the base model had a Nissan/Bose audio system. Base models seated two, had no T-bar roof, and came only with 5-speed manual shift.
1992 Nissan 300ZX: Optional in 1991 models, the driver's airbag became standard this year. Otherwise, the 300ZX was little changed.
in the biblical sense, yes. yes i do.Koshin wrote:...you know me fool
funny thing is, i stopped at d'angelo's on friday and ran into frank t. we ended up eating together and he told me to see the guys at rdz too.intermilanrox wrote:If you are really interested in it, I'd give Rich at RDZ
