Looking at 350z ... need some advice
Nissan 350z / Nissan 370z general community discussion forum
hpmachine
Car: '05 EVO8 + '95 240sx
I'm considering picking up a 2003 350z touring edition with a 6spd. The car seems to be ok. It's got 58k miles on it. No big problems stand out. The only thing that bothers me is the clutch pedal. I'm slightly concerned that that master cylinder could be going out. The pedal feels nice and firm when you depress it but it doesn't feel like it bounces back as fast as it should. I've never driven one of these cars before but in my 240sx and my Evo, the pedal practically stays glued to your foot, it springs back so fast. You guys think it could be a hydraulic issue or a clutch issue? Anything else I should be aware of with these cars?? Thanks
Watermelonwarrior
Car: 2006 Cayman S 6SPD
The clutch has is very nice and smooth in the 350z. Not like evo. But I would recommend test driving another one so you can get a better idea of how it should feel.
It also wouldnt hurt to have the car inspected. I started to do this a few cars back and now I wouldn't consider buying a car without it. I bought a Cayman S and had the inspection done. I then found out that the car had its front fender painted. Looked perfect and had a perfect carfax but when they used a laser they could tell. Ended up canceling the deal
NSRsheets
Car: 2009 Nismo 370Z #85,1993 Nissan 240sx RB25DET coupe, 2013 focus
The 03's and 04's have window issues and tire alignment issues. I would recommend checking those because mine had both of those.
Retired Chief
03 was the first year for the 350Z and Nissan was still ironing out kinks even with the 04. If I was going to buy a used 350Z I wouldn't go any older than a 2005
dasoupdude
Car: 2005 Nissan 350Z
Would be better if you could get a 2004.5 or higher, (less drama, those Z's had the irritating problems eliminated)__________________________________
These are the starting VIN's for the 04.5's
Production at Oppama Plant (T) (to be discontinued at the end of April 2004)For Coupe modelsJN1AZ34D*4T160001JN1AZ34E*4T060001For Roadster modelsJN1AZ36D*4T110001JN1AZ36A*4T010001
Production at Tochigi Plant (M)For Coupe modelsJN1AZ34D*4M100001JN1AZ34E*4M150001For Roadster modelsJN1AZ36D*4M200001JN1AZ36A*4M250001
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
Dasoupdude wrote:Would be better if you could get a 2004.5 or higher, (less drama, those Z's had the irritating problems eliminated)
*cough* RevUp *cough*
Though I (knock on wood) haven't had any problems myself, it's still a problem that bears mentioning.
dasoupdude
^True true
Most of the guys I know that have the rev-ups are still a-ok.
(well the ones that stayed n/a at least )
Initial_R90
Car: 2003 Zo6 Corvette RIP BLOWN up on the dyno
2003 Evo VIII
depending on who owned it prior it could be a number of things.
clutches could aways be fixed. I would worry about the integrity of the trans more or less be worried about the clutch
another used trans trans 800+
clutch 300+
another thing my 04 had was a throw out bearing issue.
drive it for like 30 mins then let it idle and get out and listen for a slight tapping metal noise under the car
good luck
what are they asking for it ?
Return to “350z / 370z Discussion”
