I got an adapter and an AEM dryflow to play around with, but I'm wondering how well it will work.A) The AIT sensor is located behind the front bumper and is connected to the pipe leading from the resonator -- I can't just plug it into the intake like I did on my 240sx. This will read cooler air than the intake is actually getting, and I wonder what sorts of problems that could causepathfinder_se_black wrote:aem makes dry flow cone filters, u can just get an adapter and a dry flow filter from aem, but do u guys know if the jwt filters are dry flow? and another question do you know of any dry flow performance drop in filters?just wondering because i started getting rough idles at start up with a k&n and so i switched it out to oem and its acualy smoother and better mpg.
That was my plan. . good to see someone else did that. Is it bad that I want a little extra growl? I know filters aren't as popular in the R50 world, but I think it should be fun to play with this thing.pathfinder_se_black wrote:what my friend did for his vacume line on his pathy is he drilled a hole on top of the plastic part of the filter and sealed a fitting and it works.
Very nice. .Axelpkt wrote:I got no complaints with mine, I don't go wheeling so its not as big a deal with mine. Definitely has a slight growl to it.
Only wish mine came with a heat shield, but I plan on making one whenever I have enough time/motivation.
Well that's encouraging. . I may eventually do that. . on my 240, I had just stuffed it in the cone and tightened it down right on top of the wire. . hahanissandoms47 wrote:The IAT doesnt actually do much for engine control. For awhile mine was just dangling around the intake and collecting mud, ive since cleaned it off and extended the harness so that it could go inside the cone.
Went with the AEM dryflow -- used the AIT hole for the vacuum tube, and it works fine. I like the extra noise, but it def. seems a bit more responsive.nissandoms47 wrote:Lol thats what i did. Your was was easier to explain what was going on.
Well, not much of a setup per se -- just a filthy engine bay with a grey AEM dryflow stuck where the airbox was. Also, the part where the vac tube goes is real ugly lol. .pathfinder_se_black wrote:can u show us a pic of the set up, thanks.
I think I paid 50 -- just a filter, but it's dry, and washable. I got scared of screwing up my MAF sensor.fueler wrote:how much was the AEM? is it a pipe and filter or just filter?
