jaycain »
https://forums.nicoclub.com/jaycain-u101990.html
Tue Jul 29, 2008 12:33 pm
Got some new info that may help some...
If you take the connector 4 prong (four screws) out of the P61 it will fit and line up with the posts of the P60, a little solder and your good to go. I found this out by thinking that maybe I needed to do a little more soldering on my P61 and well, I should have left good enough alone... So I ruined my P61. After I removed the P61 harness connector (rounded bigger one) and lined it up with the P60, the bold pattern was identical in size, so I took out the smaller connector on the P60, changed it out with the P61 (larger) connector, noticed it all lined up, a couple dalups of solder and poof, I was back on the road. I don't know if this is a permanent fix, but it works for now!
Sorry if that was redundent...
Have a good one! Hope it helps.
JC
