Lookin at gettin 17x7 +40
lilskyline240
Car: 90 240sx w/ rb30det
what size wheel spacers should i get to put them flush with the fenders on a s13
also whats the widest tire size i can go with on the rears?
Fenvy
Car: 2005 350Z Base 6MT
just get wheels with lower offset, say 15 to 30s
lilskyline240
i can get a good deal on them...and they look sick as hell....would 15mm in front and 25mm in rear be good?
Fenvy
don't do spacers
lilskyline240
so what offset will bring the wheels flush with my fenders in a 17x7 size?
Fenvy
consider 17x8 +20
nismofly
Car: 89 Nissan 240SX Hatch
you wont find flush in 17x7, those wheels are oriented towards hondas and other fwd's, therefore theyll have offsets for those cars
look for at least 17x8, around a +20, wider would be better still...but youll at least start getting into a wider selection in nicer sizes when you get to 17x8
whiterps13
Car: white LE hatch
Honestly, dont get them. You will regret it.
If you do, put 25mm spacers all the way around.
yokota180sx
Car: 1997 Stagea RS4, r34 front
it will take 40mm in the front
60mm in the rear to be flush with roll on front and rear
stock rear id say 40mm all around
16x8 +10 or so would be flush all around most likely
whiterps13
Car: white LE hatch
ROFL, good luck running 40 and 60mm spacers.
Yokota, your idea of flush is a lot differant than most people on this forum.
In short, find differant wheels.
lilskyline240
yeah...thats what ima do...lookin for some 17x8's now....20mm offset sound right?
nismofly
whiterps13 wrote:ROFL, good luck running 40 and 60mm spacers.
id say 60 is where you start getting into some interesting wheels to make the fitment look right
however if you put it into perspective, compare them to your wheels, these would need a 35mm spacer to reach the same spec...the ever popular 17x9 +20 would need a 45mm
im not a fan of spacers period, so id say look at least for a 17x8 +20, which you said youre going to start looking for, i think they will be hard to find...
your best bet would be to find like a 17x8.5 +20-25ish and go from there, how far you go depends on what youre looking for and how much work youre willing to do fitment wise
yokota180sx
nah man, i compared that to a 17x8 +8 wheel....hardly extreme
