Look what the wonderful UPS man brought me..
ilovedrifting
Car: skateboarding and drifting
..a new gauge cluster to replace my digital peice of **** that hasn't worked in almost a year. now i gotta spend the weekend figuring out how to get the stupid thing in ima need your help 240kid
ilovedrifting
you too ntn
SeVa-S13
Car: '05 GTO 6spd
Remove the driver sider underdash bit. There will be 2 bolts underneath where your steering wheel attaches to the steering column that effectively hold the column up. Undo those two and 2 more just like them further down into the foot well if you want/need to. Pull the colum down until you have enough room to remove the black plastic trim thing that houses all the video game style buttons our cars are blessed with. It's pretty self-explanatory from there. The gauges cluster will have two harness plugs once you disconnect it from the black trim piece and that should be pretty much it and then reassemble.
ilovedrifting
sounds simple enough
navysnail
dont worry man, ive pulled all that crap before on mine when i was trying to figure that pos alarm that was wired into my car when i got it
anyways, im working saturday but other then that im good for the weekend
wangless
Car: '02 MBP WRX
i swapped my analog back to digital the other week, 1 hour. but ive taken apart my cluster like 20 times before so it went by pretty quick
what are you going to do with the digital ? want to send it to me in attempt to fix it lol ?
oh yeah, the inner harnesses is going to be a PITA IIRC. i cut off the ziptie. the harness release things are a biatch also, isliced my knuckles with a screwdriver pushing the button thing down
ilovedrifting
wangless wrote:i swapped my analog back to digital the other week, 1 hour. but ive taken apart my cluster like 20 times before so it went by pretty quick
If you want to pay for shipping i don't have a problem with it. i just wanna hang on to it for a couple days to make sure everything is ok with the new one
wangless
Car: '02 MBP WRX
can you get me a price quote ? thanks
sanioll
Car: Nissan 240SX SE
Toyota Camry
not to steal a post or anything ,but you guys seem to know decent amount of info about digital/analog clusters.
On mine backlight goes on and off, while driving, i tap on the dash hard and it someitmes comes back on.
Also, when its really cold, it also doesn't work.
I can take it off i believe without taking the whole dashboard out.
anyone knows how to fix that??
Richard Petersen
Are you saying the brightness dimmer dial control does not work on a older car? I have pulled and repaired Nissan & Honda dash dimmer controls out and it is always wear of the wipers. Repairable, but easier to junkyard the part for 10 to$20. Unhook the battery first.
