nsrZ32 wrote:Very cool
But in all seriousness, by reading your reply and such...is it more of a bling item for you (so you can say "look I have a huge FMIC") or is it a stepping stone for bigger things later so you don't have to upgrade again? Because it is definately overkill for your setup.
Alright, for those who don;t know, heres my theory on the way i'm doing up my car..
First i wanted the car to handle.. so in went a set of JIC Coilovers, Front and Rear Strut braces, and some wider tread..
Next, was my brakes... standard Ca18 brakes are complete ****.. so in went the SR20 brakes, cause why go fast when you got no where to stop ??
Next was getting the exhaust to flow freely.. thats where a Hks dump pipe with the divorced chamber, and full 3 inch came in..
A bit problem with CA's is not enough fuel.. i put mine on the dyno with a non-turbo fuel pump, and it churned 147rwhp on 11 pound while leaning the **** out.. so i have changed my fuel pump to a Walbro 255l/hour jobbie, and i have R32 GTR injectors on order ATM..
( can anyone guess here, that i am doing this in stages ???)
Next is the 'cooler, the intake and exhaust pipes.. they are extremely restrictive, so if i change them, they'll be able to flow more air too, right ??
then after that, i'll be doing a stainless steel exhaust manifold, and a larger turbo ( either the t28, or i'll just step up and go T3)..
Now your going to ask, why have i done it this way ????
Because first you need a car to handle well.. then you need it to stop.. Turbos flow more freely with a non-restrictive exhaust.. car needs fuel before i can pump more boost.. a larger 'cooler will get me lower intake temps, and let it flow more freely too.. and then the turbo..
if i did it like a lot of you guys, and put the big turbo on first, then i woulda found all these other little problems next.. and that wouldn't be fun., ruinning 14 pound on the dyno, first go, leaning out and blowing stuff up, then would it ?
there is a lot of method in my madness.. i guess i just haven't explained it yet..
Pete.
