LOOK WHAT I INSTALLED ON MY G50! :)
NOR*CAL 916
Car: 1994 infiniti q45
whats up guys ive had these for 5 months now, there great! JIC FLT-A2 VIP SERIES http://i66.photobucket.com/alb...2.jpg
qsiguy
Car: 1994 Infiniti Q45 Turbo
Sweet! How about more information. I, for one, don't recognize that part number. Are these for a Z32 or what?
Here's your photo
From where? How much? Do tell.
92FLQ
Car: 1992 Q45, 2003 Nissan Altima 3.5 SE Auto
A bit pricey at $1980 special order (looks like prepaid??) ...unless NOR*CAL has an inside deal ?
Also only for 94-96 G50...link below:
http://www.jic-magic.com/ViewP...Chart
FLT-A2 VIP Luxury Vehicle Coilover Full View Adjustable Damper Pillow Ball Uppermount Cool Bend Linear Spring Monotube Nitrogen Gas Damper Duraluminum 6061 Seat Adjustable Height Lower Bracket 40mm - 45mm Piston Dust Boot Cover FLT-A2 VIP Coilover Adjustment Guide View Application Chart
JIC introduces our new FLT-A2 VIP coilover suspension system. The FLT-A2 VIP has all the same features as the FLT-A2 but made for luxury vehicles. The FLT-A2 VIP is designed for a comfortable ride while still retaining the same handling performance and quality found in the FLT-A2. It also allows the vehicle to have a very low drop along with larger diameter wheels without affecting the compression and rebound travel of the dampers. Rigorous testing of the dampers insures that comfort and handling qualities are met while giving the driver that very important VIP stance, improve handling, and gain that agressive look. NOTE: Some applications may come with a rubber bushing upper mount for comfort and ride quality. A Pillow Ball upper mount may be substituted for additional cost and with no warranty. Please contact us for applications and details.
ADJUSTABLE DAMPER Available for all applications with 15 ways adjustability. With this feature, you are able to tune your suspension dampening up to your spec. PILLOW BALL UPPERMOUNT Included for some vehicles for the front and some for rear application. Adjustable camber plate also included for most vehicle front applications with Macpherson Strut suspension systems. Most VIP applications will come with a rubber bushing upper mount for ride comfort and noise. COOL BEND LINEAR SPRING Linear rate spring manufactured using chrome silicon metal alloy with cool bend process. MONOTUBE NITROGEN GAS DAMPER High pressure nitrogen gas filled monotube design with special stable viscosity index oil that will not be affected by wide temperature changes. Some applications come with inverted damper system which will give an extra durability to the suspension performance. DURALUMINUM 6061 SEAT Made out of durable and light weight alloy, manufactured using machining process. ADJUSTABLE HEIGHT LOWER BRACKET More durable than factory brackets with adjustable ride height ranging from 0.5" to 3.5" drop without sacrificing the suspension travel. FLT-A2 VIP is engineered for a maximum drop with a longer damper and longer brackets. 40MM - 45MM PISTON Within the dampers are either a 40mm or 45mm piston along with bump and rebound shims that define the valving characteristics. DUST BOOT COVER The dust boot cover protects the shaft of the damper of any debris. Application Chart Model Type Part No. Front/Rear Technical Notes Product Images MSRP
Acura Legend 91-95 KA7 KA7FLTA2VIP TBA $1,980 RL 96-04 KA9 KA9FLTA2VIP TBA $1,980
Infiniti G35 Sedan 03-07 V35 V35FLTA2VIP 9kg/6kg $2,100 I30 96-99 A32 A32FLTA2VIP 8kg/9kg $2,080 M35/M45 05-07 PY50 PY50FLTA2VIP 10kg/7kg $2,165 M45 03-05 Y34 Y34FLTA2VIP* ** 9kg/7kg coming soon Q45 94-96 G50 G50FLTA2VIP* ***** 9kg/7kg $1,980 Q45 97-00 Y33 Y33FLTA2VIP * ** 7kg/7kg $2,298 Q45 04-06 F50 F50FLTA2VIP** 10kg/6kg $2,280
Lexus GS300/400 93-97 JZS147 JZS147FLTA2VIP 12kg/8kg $2,098 GS300/400 98-05 JZS161 JZS161FLTA2VIP 12kg/8kg $2,098 GS350/430 06-07 GRS190 GRS190FLTA2VIP 13kg/8kg $2,030 LS400/430 91-00 UCF10/20 UCF10FLTA2VIP 14kg/7kg $2,080 LS400/430 01-06 UCF30/31 UCF30FLTA2VIP 14kg/7kg $2,100
Nissan Maxima 96-99 A32 A32FLTA2VIP 8kg/9kg $2,080 Maxima 00-03 A33 A33FLTA2VIP 8kg/8kg $2,098 Maxima 04-07 A34 A34FLTA2VIP 7kg/6kg $2,180
*Special Order Only. Confirmation Required. **Core Charge Required($400 - $500)/Spindle Type. ***Progressive Rear Spring, No Uppermount Included. ****Progressive Rear Spring. *****Specify front lower bracket bolt diameter. Either 20mm or 22mm sizes.
Note: Spring rates may change without notice for product improvements.
© 2005 JIC Magic Home | Products | About JIC Magic | News and Events | Dealers | Test Fitting / R&D | Gallery | Contact JIC Magic | Links
NOR*CAL 916
yup $2020 i got them straight from JIC USA, they ride like a dream im just looking for wheels now, anybody have any good jdm vip 19" wheels? SSR VIENNA KREIS maybe?
ponzy
Car: infiniti q45
nice ...........is the "PILLOW BALL UPPERMOUNT" is the adjustable upper link, right? the picture taken was from the rear, right? it's all corner for 2020?
qsiguy
Too rich for my blood! I have about $550-600 invested in my cali customs, Tokico's and Infiniti shock dust covers. That's as good as my car is getting. Very nice tho if you have the budget for that. So the height is fully adjustable with those? That would be nice.
ILuvNkdChx
Car: Q45t, I30t
Ha, at least your Q was the cheapest on the list, even if only by $50. They look good, and can only imagine how GREAT they ride.
Rex
Car: None
NOR*CAL 916 wrote:yup $2020 i got them straight from JIC USA, they ride like a dream im just looking for wheels now, anybody have any good jdm vip 19" wheels? SSR VIENNA KREIS maybe?
You see these?zerothread/248197
NOR*CAL 916
the suspension is fully adjustable regarding height and dampening its a wonderfull setup i had the tokico blues and eibachs but i needed more. i will post pick once i get rid of the stocker 15" Thanks guys
94infinitiq45
hey Norcal would you be interested in selling your eibachs,and for how much. thanks,jerrod
silver2k2
Car: 1994 Q45 Ivory Quartz/Tan
I already have them Thanks Art I put them on last weekend.
apossiblehybrid
Car: 1994 Q45
post up some full view pictures of your car.
