ziggy682 »
https://forums.nicoclub.com/ziggy682-u3095.html
Wed Jul 14, 2004 11:20 am
That looks exactly like my turbo.
Let me clarify what Checkered-Member was saying. You won't be using the internal wastegate if you didn't get the turbine flange with your turbo. The Z31 turbo has a unique bolt pattern, so no other flange will work with it. Since the flapper for the wastegate is in the turbine flange, you can't used the wastegate without it.
