Look what came today!!!
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
HAHAHAHA It finally came!!! UPS didnt show up till 3:30pm and it was raining all day so i just sat around the house bouncing off the walls. But its finally here!!!
And just to compare the old vs the new....
Well its 10pm and i stopped working on it around 9pm, but its fully installed and bolted back together. I just now have to have someone start the car while i hold the impeller from moving to let oil circulate through it, then i can begin installing the boost controller.
FRSport RULES!!!!
Jason
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
FRsport does rule. No complaints here. Congrats on the mods!
riken1337
Car: 90 s13 CA18
unhook your CAS and crank the engine for a good 20 seconds about 3 times and you should have the oil system primed.
mazikowski
Car: 2013 Subaru BRZ Ltd 6MT, 1984 CA20E 200sx, 1981 L28E 280ZX
stupid question... but how would one hold the impeller wheel from moving to allow oil to circulate?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
^ Don't do that Maz. Just crank it w/ the fuel pump fuse or the ignition coils unhooked.
JNM240
I was told to let the car idle with the air intake tube disconnected and holding the impeller to keep it from moving for about 3 minutes to let the oil cycle through the turbo. The car will idle with the MAF off of it, so i was assuming this was an acceptable way of priming the turbo. Cranking it over with no fuel pump or no CAS, wouldnt there be air still coming out of the head trying to spin the turbo over? Isnt that what im trying to avoid, spinning the impeller until it gets oil pressure for the first time?
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
the Low rpm's arent really what kill it... +1111111111111111111111111111111111111111111111111111111 for unhooking the cas
float_6969
I always unhook the CAS, remove the plugs, pull the fuel pump fuse, and crank it over till the oil light goes out, then count to 10. Never had a problem.
