Gcustoms »
https://forums.nicoclub.com/gcustoms-u141748.html
Sat May 29, 2010 6:19 am
It was alot of fun trying to do the rear stabilizer links with urethane bushings and the rear brakes at the same time. The stabilizer links I had removed a couple days before so since then the car has just been sitting in my school's parking lot. I get the links lined up in the swaybar and control arm, push the bolt through and... of crap... i can't thread the bolt on. So my buddy B-roy decides to let the jack down-the stabilizer on a piece of wood. Of course he lets it down too quickly, I thought my nice new urethane bushing were f***. they werent but it pressed the bushings into the retainers so the nut was able to thread on the bolt. We thought after that - nothing else could go wrong.
WRONG! my rear brakes were seized on there like nothing I've ever seen, after a hard 20 minutes of prying and pulling trying to remove the caliper we finally managed to crack enough rust off to remove it. Fine, we remove the old pads, remove and clean the clips, remove the brake assembly bracket to remove the rotor. BAM rotor's seized on there, we found a square piece of steel heavy enough to dislocate the rotor, it worked! We lubed the pads, clips, sliders/guide pins, put the backing plate on the pads we thought we were good to go. NOPE - it's a self adjusting piston so as you compress the piston something has to turn it in order for it to go anywhere. FUUUCK, So there we are, chillin in a parking lot, it's getting dark, I have $400 worth of tools and equipment and none of those tools happen to be any use at that peticular time. Good thing the custodians were working and happened to hear our violent knocks on the door, he let us in and we found a c-clamp with an 18mm bolt on the circular end pad, so we figure if we can keep tension on the on the piston and turn that bolt simultaniously it might turn the piston. HOLY CRAP SOMETHING WENT WELL!!! it worked like a beauty. LET THIS BE A LESSON TO ANYONE WHO WANTS TO DO THEIR OWN BRAKES, USE THE SEARCH BUTTON ON NICOCLUB FIRST LOL
Anyway, long story short, the hot blonde asked for my number.
