Look at the big fat phony!!
Chezedik
Car: 1991 Nissan 240sx
Do these oil lines look familiar to anyone:
http://cgi.ebay.com/ebaymotors...QrdZ1
D Money
Car: driving illegaly
there was already a big thread on this a while ago
Edub1
Car: 89 240sx KA-T
Hay, why not make a buck or two...
Anyway, that is the DIY line in the sticky, right? Could this be used with a standard T3 inlet flange? I'd feel more comfortable with the proper flange.
Also, how does one convert from "an" to inches? What is "an" anyway?
Flange, defenitly have to have the flange.
Chezedik
AN is Army Navy, it is an aeronautical standard. Also very expensive stuff. The number 10-AN, for instance, represents the number of 1/16ths of an inch. So 10-AN = 10/16 = 5/8. 6-AN = 6/16 = 3/8. Get it?
Edub1
Car: 89 240sx KA-T
Thank you, good to know. So, I can just look for 5/8 ID stuff to make my return line.
Chezedik
That is what I am going to do, is use some 5/8" pipe nipples, but I think I mentioned that already.
Edub1
Car: 89 240sx KA-T
What kind of "nipples" are you talking? I guess I could get some stock steel and make a couple of flanges. Brazing ought to hold don't you think?
I was out with my engineer friend last night and I brought it up and he confirmed that turbos have those flanges for a reason and that a virbating hose will, over time, be likely to cause a fitting to break off if it is threaded directly into the turbo without the flange.
I might even try a Ford dealer since my turbo is from a Ford. Hope it's not like $49.99 each.
Chezedik
I would go with welding rather than brazing for that reason. And no it probably is not as likely to break off, but I would be surprised if it ever became an issue (if you welded). A nipple just looks like a little piece of pipe about an inch long. They are used for butt-joining two pieces of pipe.
Chezedik
Oh, and try ebay. Those flanges are everywhere, and cheap. Just use antisieze since they are aluminum, or you could be worse off than my idea.
KATwo40
Car: 1993 240sx KA-T
haha you said "nipples"
Edub1
Car: 89 240sx KA-T
Cheze, how are you suggesting using this nipple? To go from hose to hole & from hose to bung?
BTW, the Ebay flanges are aluminium. I think it should be steel or at least brass.
Chezedik
Weld one on the pan, and using another and some sheet metal, making a flange with a nipple, then using hose and clamping it down.
Aluminum should be fine, the only thing will be to use antiseize anywhere they contact to prevent electrolysis (sp?).
Chezedik
Edub1
Car: 89 240sx KA-T
Or just cut a piece of 1/4" steel and drill and thread it.
Chezedik
Yes, you could do that too.
hannibal
Car: Red Line to Glenmont
That luke guy is a brother of a NICO member.
Never knew what AN stood for or how to convert to inches. Good info...
Chezedik
Ah...
