Long tube Manifold for 240sx drag car
Showdown
Car: Depends which day it is.
Just got done, didn't get to weld because i ran out of gas.
Showdown
Showdown
Lil_JV
Car: 1991 180SX
May I ask, what is the advantage of the longer tubing?
Thanks,
JV.
USsil80
d@mn dude... 9.9 what class are you wanting to run in
Showdown
Nopi turbo 4
USsil80
dag 9.9 with just the turbo..sucks that we can't run a nitros kit becouse of the motor swap.....any other insite to your setup.....please
VitaminT
Car: 93 240sx SE
There is a car around AL that someone did that on. I believe it is owned by the owner of SPEC clutches.
I think I can get a few more pics if anyone wants but didn't want to flood the thread with pics too bad.
USsil80
i would love to see more also what else that car is running
f150intally
USsil80
wow very nice... has anybody run a long tube on there car yet... also where are the advatages on them compared to a equal lenght header
Nismo_Freak
Car: 89 Nissan 240SX
USsil80 wrote:wow very nice... has anybody run a long tube on there car yet... also where are the advatages on them compared to a equal lenght header
Greater evacuation of the cylinder... works on the same principle as header modifications on an n/a engine.
Creates more lag though.
USsil80
more lag mmmm but would this creat more of a flow through the header to run a larger turbo.. so uping the redline would be really helpfull on something like this
Nismo_Freak
USsil80 wrote:more lag mmmm but would this creat more of a flow through the header to run a larger turbo.. so uping the redline would be really helpfull on something like this
It will spool the turbo slower for the same reason that it creates more power.
A shorter manifold has less volume, ergo it takes less time to pressurize the manifold which is what creates deltaP within the system. Once you have achieved pressurization of the exhaust manifold you speed up the flow over the turbine blades, and increase the mass flow. The problem is... once you have spooled the turbocharger the manifold can become a restriction of sorts due to the short runner design not scavenging the cylinders as effectively as it could with longer runners.
BTW, you should opt for a Civic Koyo radiator. Cut down on about 1-2 gallons of water and that'd save you 5-10 lbs.
own3d
Car: 95 FD3S
so basically you give up some spool time for more top end power?
Nismo_Freak
own3d wrote:so basically you give up some spool time for more top end power?
Yup... in drag racing spool really doesn't matter. You can just run a bunch of nitrous / anti-lag and you're good to go.
Showdown
Damn right!
sdtouge
Car: 1990 240sx coupe
i dont see how the lag would even be noticable, i tihnk it would be the same as on a manifold that closer to the head. it still has to go to the intercooler, this is just lengthining the manifold, and shortning the hot pipe i tihnk.
i actually have no clue, have no calculations or expirience, i just think this would make sense....
