So Kimber Kenobi, She who loves her Versa and some other long time Versa vets, keep an eye on your battery. Don't want to see you stranded.
That's what I'm thinking.probably only a 36 monther, isn't it?
williamk10 wrote:I am going with Optima Red Top.
Might as well go with the best.
That's probably what I'm going to end up doing too. Might swing by Costco on the way home from work today...NODES wrote:Costco (Kirkland brand) batteries are good for the price you pay. I have never had one fail in our family and we have been through a lot of cars/different batteries through the years.
Eemrek wrote:That's probably what I'm going to end up doing too. Might swing by Costco on the way home from work today...NODES wrote:Costco (Kirkland brand) batteries are good for the price you pay. I have never had one fail in our family and we have been through a lot of cars/different batteries through the years.
Cheers,
Eemrek
I think the Bluetooth "might" (i.e. pairings, contacts, saved voice-activations) survive a battery disconnect. I think it's basically the clock & radio presets. All the other ECU/BCM functions should be fine; they're all EEPROM (flash).srellim234 wrote:Questions: If I have someone like Costco change the battery for me do I need to worry about any of the electronics? Other than the radio presets and possibly the bluetooth is there anything affecting engine functions I should concern myself with?
Will do!NODES wrote:let us know if it makes any difference in the way the car runs.
Eemrek wrote:Costco - $56.99 + Tax (WA State)
$9 Core Charge. Refunded upon return of old battery -- READ: Means next time you go to Costco and blow hundreds of dollars there because it's so easy to do so, you get your $9 back!
Car definitely turns faster when starting from cold. Other than that, lights (both interior and exterior) definitely stays brighter when I start. The OE battery is on its 51th month in service so I just called it "preventative maintenance" for about $60 and change.
Cheers,
Eemrek
LOL! TouchéNODES wrote:"preventative maintenance" eh??? does that include changing you oil more frequently now too?![]()
P.S What is the point of the white battery cover....why could they not use black.
Yup. BT and BCM related stuff survived the 5 minute battery swap. -- I forgot it also reset the trip meters on the instrument cluster and forgot to mark down the mileage so now I'm going to have to backtrack from my last odometer reading to get a proper MPG calculation on the current tank of gas I have.NODES wrote:The BCM will get reset if it is unplugged for longer then a couple of hours, a battery swap should only effect clock and radio.
Hmmm. That black piece of rubber was in the middle of the plastic battery cover when I changed my battery. It fits perfectly between the retaining bar and plastic battery cover when you tighten the battery bracing. I would presume it's to prevent the rear retaining bar from possibly rubbing into the battery casing over time.There is a small rectangular "insulator" (I think it was some type of rubber) that's black and adhered on the lower left-hand side of the battery cover behind the positive-terminal towards the driver. Not sure why it's there because I don't see anything that would need it to be insulated from in that general area, heat or otherwise.
