kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Mon May 06, 2013 12:26 pm
The Rogue has very few maintenance items, especially if you have FWD, you've listed all of the major items other than perhaps spark plugs - if you haven't already new spark plugs can make a big difference although you may still have some life remaining. If you have AWD then you'll want to change your transfer case and rear differential oil, there is a DIY article for you to follow on this forum as it is a fairly simple process.
If its still running well and getting consistent gas mileage I think that's it, you're good to go. After you get to higher mileage and you start to notice reduced performance you can consider cleaning the intake include MAF sensor, and some will recommend a fuel system flush which cleans your injectors and intake manifold, restoring power, efficiency and performance. Some even claim that these products will clean out your upper catalytic converter but I'm not so sure I'd believe that, although it probably can't hurt. If your state or province offers "smog/emissions tests", this is a good way to know how your engine and exhaust system are functioning - just one more piece of information to judge how things are holding up.
Regarding synthetic, there is a ton of reading you can do on the internet and on this forum. Basically it can help in extreme conditions such as hot dessert driving or very cold winter starts, and the oil is designed to last longer with more cleaner additives. But if you run conventional oil it too has lots of cleaners and conditions, it just won't last as long and you'll need to change it more often. Follow the maintenance schedule and you'll be good to go. I switched to synthetic because I don't have to change the oil quite as often and instead of sending 4 oil filters to the landfill and 4 jugs of oil to the recycler I only send 2 - less impacts on the environment, may not seem like a big impact but if you look at the millions of cars on the road it makes a difference!
