OP240sx »
https://forums.nicoclub.com/op240sx-u15812.html
Fri Feb 11, 2005 12:33 pm
I searched all the topics with "starting" in it, but nothing resembled my problem.
I had some remanufactured injectors installed at the end of December '04 to replace the leaking OEM's in my 1990 240sx. Once the car is running, it's great, smoother than before. It's just getting it started that is the problem.
Let me first say that the car has always started, it just take about 3 seconds of cranking followed by some short sputtering (very embarrassing when there are people around ). I had Nissan install them with all the new O-rings. The injector company recommended getting the fuel rail, intake, etc cleaned after installation. We waited until today to get that done just to see if the problem would fix itself.
After having the fuel system service done (never been done before on the car so that's why we did it), it still starts poorly. A member from another Nissan board suggested that the O-rings might be leaking air causing a vacuum leak, but one the car warms up, the O-rings fill the gaps. I am no expert by any means, but that makes sense to me.
Comments?
Note: the dealer did say they would take it apart again to make sure everything was done right, so at least I can always fall back on that.
