evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Oct 07, 2008 3:05 am
?? I'm confused?? you have an RB swapped S13 and with an S130 turbo and want the flange to match the outlet of the S130 turbo?
if thats the case I don't know of anyone selling just the flange, you can buy a complete downpipe form MSA which may or may not fit your engine/chassis, I'd think you can take S130 downpipe/O2 housing to your local machine shop and have them cut a flange, it' might cost about as much as the mandrel bent downpipe form MSA
the nissan T3 has a fairly restrictive wastegate opening and door, I'd think the better solution would be an off the shelf turbo which uses a standard outlet flange and lager wastegate flapper
