long dual cold air intake vq35hr
dohio69
hi besides the stillen stage 3 intake that works in front of the radiator¿? and the injen cold air intake that seems to me the only one, in there other brands/models to check? please post manufacturers links...
joe603
Car: 2014 Durango R/T
Welcome to NICO!
Check out the G-series FAQ page (link in my sig) for lots of info. There is a link that has aftermarket websites.
suby01
Car: 2007 Infiniti G35x
those are pretty much your choices for the CAI. however i would recommend not getting them for the troubles in install and need to modify your car cut out a few things etc. plus a few people had issues with water intake through the CAI.hope that helps.
dohio69
hi again, i live in a kind of dry location so it would be ok, do u have stillen gen2 o 3? and how it works?
suby01
not talking about location you wash your car or ever take it to the car wash?
i have the long tube gen 2 see signature.
dohio69
hi , sorry i couldnt see if it was #2 or #3 there, but i always since my first short intake use to cover my filter with a plastic bag been careful to take it before i start the car again (not great no see what happend if you forgot in a k&n!!!), its common knowledge engines breaths air not water so im avoiding weather/car wash topics, thanx for the help anyway but just wanted ideas about gen3 vs the injen one???
Modified by dohio69 at 3:13 AM 12/30/2009
suby01
comparing stillen cai gen 3 to injen cai. the injen has better power gains throughout the power band . i dont know the cost of each but i would go for the injen in that case. out of those two.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
I doubt the Injen has better power. If I'm not mistaken, heat soak will reduce the performance. You can't go off the manufacturers dynos. They just want you to spend your money.
I'd look for some independant dyno's for each.
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
I have the Gen 2 in the EX and love it.
suby01
tollboothwilley wrote:I doubt the Injen has better power. If I'm not mistaken, heat soak will reduce the performance. You can't go off the manufacturers dynos. They just want you to spend your money.
your right. but going off of manufacturers dyno the injen is better like i said. and also seeing and installing both in different cars, the injen quality and look and finish for the CAI is a lot a lot better. like i said i dont know if theres a big price difference but if not then injen for the CAI
dohio69
i thought that too, ill try to get an injen then... hey suby01 i guess its the same platform for all g35s so all springs should fit right? anything else to add or adjust for your eibach ones in your x? i dont know why all brands exclude awd models... let me know, thnx
tollboothwilley
they exclude X models because you can't change out the X shocks with aftermarket to match the springs....they just don't make any aftermarket shocks.
suby01
dohio69 wrote:i thought that too, ill try to get an injen then... hey suby01 i guess its the same platform for all g35s so all springs should fit right? anything else to add or adjust for your eibach ones in your x? i dont know why all brands exclude awd models... let me know, thnx
correct. you have to look for 07+ G35 sedan springs and they will fit.
no company offers it for the X.your choises are tanabe with least drop eibach more dropH&R biggest drop.
once you pick which ones you want, when shopping look for altima springs they are the same part number at a lower cost.
