long cranking start up
predator93
Car: 93 300zx na
bought a 93 2+2. since getting car wont start unless gas pedal is fully depreesed.. even when fully depressed it takes a long time to crank. any suggestion.
predator93
Car: 93 300zx na
i have a 93 2plus2 with 101199 miles. car will start but takes a awhile to start and the pedal has to be fully depressed in order for it to start. found radio harness was cut wondering if this has ne thing to do withit. also lighting issues. i am a nissan fan had a 96 modded maxima which jus died. i was palnning a vh45dett swap but i am forced to jus drive as is so can ne one help. at least with harrd start??????
oldschoolnissan
Car: s13 240sx
check compression n codes sounds like fuel though....
predator93
Car: 93 300zx na
knock sensor code and good compression
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Welcome.
Depressing the gas pedal does nothing on a fuel injected car.
Check your battery voltage, then check the health of your starter. I suspect the starter in this case.
J30tChumpCar
Car: 1995 J30t Totaled @ Charlotte motor speedway
1994 J30 gutted caged road racer Now with VH45DE!
1966 Chevy Corvair V8 mid-ship conversion
Does it start with a puff of black smoke? If so its injector issue of some sort.
J30tChumpCar
Sorry to provide conflict but flooring the gas during cranking on a fuel injected car reduces or discontinues injector pulse to introduce a "clear flood mode"
300ZXttZMAN
Welcome!
BigTDogg (MA)
J30tChumpCar wrote:Sorry to provide conflict but flooring the gas during cranking on a fuel injected car reduces or discontinues injector pulse to introduce a "clear flood mode"
Can you confirm that with Datascan or the like? You're saying if you floor it while cranking, injector duty cycle goes to 0% to clean out the cylinders of any fuel flooding?
BigTDogg (MA)
Posts merged, no need to double post.
predator93
Car: 93 300zx na
@ biggtdogg i look at all the other post and there was no answers. i started a new one.also i measured the voltage and only has 5 volts....? i though i was suppose to have 12 volts to the pump...? any advice
NolimitZ32
FSM has all the answers.
BigTDogg (MA)
predator93 wrote:@ biggtdogg i look at all the other post and there was no answers. i started a new one.also i measured the voltage and only has 5 volts....? i though i was suppose to have 12 volts to the pump...? any advice
You can reply to the original post to move it to the top of the forum, to get more visibility.
Measured the voltage where? At the battery? At the battery with the car off you should have around 13.2VDC. With it running you should be around 14.4VDC.
predator93
Car: 93 300zx na
@nolimit what is a fsm.. im a newbie
NolimitZ32
everything-you-need-to-know-about-the-z32-t508377.html
Second link on the above page.
FSM = Factory Service Manual. It has a whole section on troubleshooting certain problems and I'm fairly positive what you've got is in there.
300ZXttZMAN
predator93 wrote:@nolimit what is a fsm.. im a newbie
LOL don't feel bad I asked the same thing when I first joined ha. Nolimit was the one that told me what it ment also :chuckle:.
Ahh good times, good times.
