long crank time
3jpz418
Car: 192 nissan sentra xe
i have a stock ga16de in mu 92 sentra and i have extremly long crnk time in the morning. if i open the throttle just a little it will putter to a start, same happens if i dont open the throttle bit it takes longer. i have a haynes manual and a chilton manual they have different dead head pressures, regulated,and unregulated. what are the specs and how long should the pressure test be??
Touchdown038
Car: Computers, cars, sports
Sounds like low compression, meaning worn rings.
How far off are the two manuals? Usually below 120 or so is considered pretty worn.
hudy
Car: 1991 240SX SE Hatch
what is fuel psi while cranking?
