DjPantsSpecR wrote:45mm, exactly what i want. However my prototype manifold had stock, unported runners and netted significant gains. So you can look forward to a few underlooked ponies as a result, at least theoretically. we'll know in practice. I also had gasket matched the head and runners. which i know youre going to eventually do, as i have read that thread.
i think for shiggles we should continue working with 93, maybe a modified map. It would be interesting to see what kinda gains are possible on pump gas.
course like i said, i dont know if i got screwed on the manifold yet, i might jsut have to try adn make the pieces and have them welded.... but 45mm is around ideal, jsut incase someone was looking to sandwich in some ITBs.
Well sorry to here that someone is taking to long on those manifolds. Peopel that do good business always stay informed and in contact with there associates.I would of gotten into the business of welding the manifolds as well, but it is to expensive and competitive when competing with chinese manufacturers. For me to sell a manifold it would run almost $600. Thats the cost for one fabricated flange, 4 runners, 4 bosses, and for me to weld it with a plenum.Not including port match or TB porting.
As far as 93 octane it is more than streetable for a KA24de to make gains. JWT keeps ignition low and just allows enough fuel to be dumped to keep the car smogable, and SAFE, I believe is the term they use. No doubt the ignition MAPS on a JWT can be advanced and increased and more fuel would need to be added that wouldn't make the car smogable with an eprom tune. But 93octane can make more power with a few changes.One of the reasons why I stayed OBD1 is that it is easy to advance the distributor to my liking and change the fuel curve without a lot of serious hassle or eprom tuning (like willem or tuner pro). If you do have a JWT tune no need to change the maps just add more fuel with SAFC and advance the timing a bit, (I think you will be surprised).
As far as gasket/port matching it isn't practical for me, I am a bit more methodical on port and honing. As you can see in my thread I haven't used any gaskets yet. I try to calculate more because if people just always follow a gasket for there port there is the chance that they decrease velocity somewhere in the runners by increasing to much diameter from the gasket tracing.Enough chit chat from me, keep up the good work on the KA info (AJAX, and DJ) I do read what you guys have to say. AJAX if you did get F&%Ked sue big time.......
