Ok Mod List
The Previous owner bought it in 99 in 2004 he swapped the sr20det engine and manual transmission
new nismo engine and trans moounts
stage 2 exedy clutch--BROKE
Now has an ACT 6 puck sprung disk and HD pressure plate
full stainless steel tubular turbo manifold, 3" outlet pipe (common point of post turbo restriction), 3" down pipe, flex pipe, magnaflow high flow catalytic converter and rare espiler exhaust with a 4 inch outlet ( sounds amazing)
AC works which is uncommon in this swap from what i understand
300ZX tt LSD and 2 piston fixed rear brake setup
4 piston fixed front brakes off of a skyline
enkei 18x8.5 front and 18x9.5 rear wheels with a beautiful staggered offset
relocated battery to trunk to make room for the custom hot and cold pipes going to the large GReddy FMIC and a Blitz BOV
ported and polished throttle body by BDC Motorsports
all aluminum Koyo radiator with silicone hoses
high flow water pump
custom made full core dual fan shroud with dual electric fans and variable fan controller
300ZX tt fuel pump is installed in a brand new from nissan fuel tank
Tein flex coil-overs with pillow ball camber plates built in
nismo tie rod ends and pillow ball tension rods
power enterprises boost gauge and controller
fujita intake
seibon DV style carbon fiber hood
one german style glass headlight soon to be both!
nismo 270R 6 piece body kit to be installed.
energy suspension bushing kit
and a GReddy full auto turbo timer to be installed when the turbo is upgraded
