Coolant leak, Unsure where from
randOmcLamsheLL
Car: 1991 300ZX NA 2+2
ok so my car overheated fro the first time ever today, had to get her towed :(
this is exactly what i did:
saw where the fluid was spilling from, it seemed like it was from the reserve originally (the plastic tube behind the driver headlight)
let the car cool for like 30 minutes, took the cap off the rad and it was empty..
put in 50/50 and while i poured i checked to see if it leaked, and it was from there..any ideas? tony?
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
I'm not down with the artsy picture. Is it leaking from your lower rad pipe?
randOmcLamsheLL
lol hahahahaha ill get a better picture tomorrow i promise ;D
300ZXttZMAN
I guess you dont want to get dirty?? Grab a flashlight, jack, jack stand and a tampon then crawl under your damn car and look its not that hard. :chuckle:
randOmcLamsheLL
so i discovered the leak was coming from the coolant lines..now a bigger issue, my gas pedal is stuck! i took off the intakes to get a better look, and the passenger side opens up a little but, but the driver side is stuck shut...do i need to replace to throttle body?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Most likely sticking due to either the throttle cable seizing or one of the linkages getting caught on something. Go under the hood and turn the throttle linkage by hand (not using the cable) and see if it binds. If it doesn't bind without moving the cable, it's most likely the cable needs to be lubed up.
randOmcLamsheLL
tried it, no luck...why wud only one open a little bit? they are both connected together right?
robomatic12
Car: 1990 300ZX TT
Make sure the pcv's coming from the valve covers haven't backed out catching on the throttle linkage.
jaredta1a
Car: NA 1991 300zx
1993 240sx Hatch
thats a simple nuts and bolts issue man, disconnect the cable and look at it really hard, you probably bent the shaft somehow
