NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Wed Apr 13, 2011 7:24 am
Does anyone know of a Loggable Dual EGT controller on the market, I am getting ready to install a wideband and while I'm in there want to install EGTs on both banks for tuning and monitoring purposes. I have found a lot of different setups for dual channel EGT gauges but non that are loggable/compatible with other systems. I have an Innovate LC-1 wideband setup and am in talks with Innovate about using their SSI-4/MTS to combine the LC-1 wideband, dual EGTs and a RPM signal so I can log that and Nistune outputs separately and then combine the info in spreadsheet form. Basically what I am asking is for suggestions on a system that can run a single or dual AFRs, dual EGTs, and RPM signal and most importantly be loggable and have a built in graphics output (gauge) or have the ability to add a gauge in the future.
Thanks
Anton
