Locks stopped working....help!
Forum for the unique Murano, and official home of Nissan Murano Club!
marcink99
ok fellas my 04 27k miles murano has some problem on it!! my all 4 locks stoped working. I have extended warrentl whent to the dealer and he blaimed it and my aftermarket alarm claiming it was sending close signal to the all locks at all times and burned them out.(actuators) I dont believe this because why would be working for year before stoping.???( Dealer did't fix it) offered me 1600 service aswell ....DO you guys have aftermarket alarms and experiencing problems?
So i took the alarm off and now my drivers seat is not working properly meaning it wont slide front and back and car will sometimes start and shut down right away. Is this all coincidence??? or did i do something wrong???!!? Please help
I believe that a problems is bmc. This is the part that sends current to locks , power seats and some more thinks.Would explain why my car is geting worst.
Ideas??!?!?
joe603
Car: 2014 Durango R/T
Were did you have your alarm put on? I'd see if they've had any problems like this on other vehicles.
You could....take the alarm off and then take it to another dealer....
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Sounds like a bad wiring job to me. Can you take it back to where it was installed? Or did you install it?
marcink99
it was intalled by the pros a year ago at the shop that those only audio and alarm work.Also please note lock were working after alarm installation for about a year or so.
Modified by marcink99 at 5:34 PM 8/13/2008
Sentientbydesign
96 I30 - Sold
Heat/cold and humidity can easily create a problem.
I don't know anything about the shop you went to, but I've seen many places that call themselves professionals and that only refers to the fact that they get paid for their work. Not that their work is top notch.
If the locks are all burnt out, it could be because they were exposed higher voltage than they were designed for. This is why 130V light bulbs have longer lifes than 120V (the voltage they actual run at). You may have a short also. The aftermarket alarm system may have been continuously feeding current to the actuators even after they were unlocked/locked...there are quite a few possibilities.
C-Kwik
marcink99 wrote:ok fellas my 04 27k miles murano has some problem on it!! my all 4 locks stoped working. I have extended warrentl whent to the dealer and he blaimed it and my aftermarket alarm claiming it was sending close signal to the all locks at all times and burned them out.(actuators) I dont believe this because why would be working for year before stoping.???( Dealer did't fix it) offered me 1600 service aswell ....DO you guys have aftermarket alarms and experiencing problems?
Unless they used some strange method of installing the door locks, I can't imagine there being a signal to constantly lock the doors. Each function (lock and unlock) usually has its own relay and will be a normally open circuit. Any incorrect wiring to the relay would likely result in the unlock function not working as the actuator would be held locked by the lock function relay.
I would probably ask the dealer to explain it in detail. Perhaps approach them by saying you want to go after the alarm shop and you need to understand how they concluded that the alarm was to blame. Either, they will give you legitmate ammo to put the alarm shop on the hook, or they contradict themselves and you will have ammo against the dealer.
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
^^ i am glad i read that before i posted what i was gonna say... +1 my advise would be along those lines
pm_page6776
Car: 2009 A/C 2.5S
It is not the aftermarket alarm. I never found the reason for all four door lock actuators going out at the same time, but I have seen it happen on both a 05 maxima and an 04 murano. Both times I put actuators in them and they haven't come back. Take it to another dealer.
marcink99
Thanks guys i really apreaciate you comenting on my lock problem. Iam going to the dealer on friday morning. Just out of curiosity will another dealer know that i had this checked out at a difreant dealer before coming to them? Also any idea an my seat problem? It seams that only one side of the seat moves while other is stock or something.
Sentientbydesign
96 I30 - Sold
The service logs can be pulled up by any dealership, so technically yes. Especially if it's the first time you've visited this "new" dealer.
marcink99
hmmm i think i will just go in and pretend like my locks and rest of the car stoped working and not tell them about alarm.Afterall i have warrently why should i even fight with them over this
Return to “Murano Forum”
