locked out
`def-zero
hey maybe im stupid and missed a page in the manual but when i turn on my 240 and try to put it into gear it locks me out of all the gears however when the cars off none of the shifts are blocked. any ideas? yea i know im a newbie with tons of posts hah.
ninjak84
Car: S13, Z32, Titan
Is the clutch pedal pressed in?
`def-zero
haha - yea
specialkonrd
check your clutch hydrolicsit might not be lifting properly
red240ne
Car: mmm...donuts
doesn't your brake pedal need to be pushed in too? if your shift lock is messed up i think you can just pull the fuse out of the fuse box to make it not function. although, it's probably not recommended to keep it that way, because you might need it some day on a hill or something.
UnderPressure
engine mounts, look to see if they are torn/broken. the engine could be moving out of alignment with the transmission not letting you shift. i couldnt shift into first when mine broke.chris
`def-zero
clutch line was loose 25 min fix no biggie
