going outside right now and give mine a wack wish me luck...lolTgvince wrote:There is a little switch in the glove box that only allows the key too work...thats not the problem with mine.I did however get in! Pure luck be it good or bad:). I removed the lisence plate hopeing to see what i dont know but in fustration i smacked the area behind the plate...I tried the release on the door a couple times and behold the trunk poped open! WOOHOO! I pulled the cosmetic panel to see what the heck was up...It appears that a stupid little nut had loosened up off of one of the tail lights and found a home in the latch mechanism apparently when i whacked the decklid it jarred it loose...I got ultra lucky, so i thightened all the nuts on the taillights and all were kinda loose by the way....So no holes drilled or knocked out lenses or worse:)...Thanks for all that advised me in this delema!
Terry
