thirdq wrote:I broke the plastic cover on the door latch - now I am not sure what part to move to open the door latch.
you mean *the*DLA, as in the mechanism buried down at the rear of the door? wow.
thirdq wrote:Both of the inside rods (door open & door lock) are of course useless as the plastic pieces are all gone form the DLA (in fact the metal rods from the door are now just hanging loose).
well, unless you undid the green nylon retainer, i would think the release rod to the inside handle would still be in place, connecting to the metal part of the DLA, up high, near the plastic cover. in other words, i thought the cover was just a cover and not part of the mechanism linkage...but i don't really know as i havent taken one apart. is it possible that that rod was dangling from the beginning, before you broke the plastic off?
thirdq wrote:So, the Door latch is now completely detached with the door lock - in fact it is now 2 seaprate pieces with nothing connecting them. Now I need to figure out what to jiggle/press to switch the door lock to unlock. Kind of stumbled.....
Thanks
so, the thumb latch is not connected [the 2 piece rod with bellcrank in the middle], but you still have the key from outside and the electrical path to lock/unlock, right? problem will be to unlock, if the release mechanism 'thinks' that you are trying to open the door. kinda like when your kid [at least mine] is holding the door handle to open the door when you are trying to unlock it and nothing happens.
so, back to the previous..is there any way to 'neutral' the release action? whether lifting up the residual tab on the DLA where the blue bushing was, or pushing aft the tang on the top of the DLA where the door release rod did attach?
